Battery Backup
SOLVED
jayesh_oboroi
Visitor
Battery Backup
Hey guyz this is my battery backup...2G active always..n i use 3G sometimes...battery doesnt drain whn the phones idle...bt if m usin net or downloadin or playin games it drains very quick...ive uploaded some screenshots please have a look n tell me if its normal...thnx..
1st 6 hrs the phone ws on standby n it consumes 8% battery..
1 ACCEPTED SOLUTION
Accepted Solutions
Uliwooly
there isn't a way to find out unless you download an app to keep record of that. if you don't want to waste battery at night you can use airplane mode (press and hold the power button)
Don't forget to mark the Correct Answers & Helpful Answers
unrelated topic, if you have some time please check this thread
http://talk.sonymobile.com/message/244522#244522
5 REPLIES 5
Uliwooly
it's your display, if you have bravia on and brightness set to 100% it will drain quite fast.
jayesh_oboroi
Visitor
thnx for replyin...well my brightness is slightly less than 50% and bravia is on always...shld i turn it off?n is brightness level fine? whn m watchin some HD vid or ply some game battery drains almost every minute...is there any solution for tht?
Uliwooly
the bravia engine it's only useful when you watch videos, pictures. as for video games, there's nothing you can do about it, as it's developer dependant , just like multiple buggy apps.
jayesh_oboroi
Visitor
ohh okay...n today morn my battery had drained like 12% over night in standby...is it normal? i could see the screen ws awake for sometime like 5 mins...i dunno which app mite b actin up..how do i find tht out? google services consumed 4% of the battery...how do i find out which app suddenly woke up the screen? n how do i deal wit it..?
Uliwooly
