Hi,
I bought arc s 2 weeks ago. And now I have just realized that down the side with the headphone jack there is a gap between the metal border and the edge of the battery cover. Does anyone has this prb as well. What should I do? I haven't any other prb with this phn but only this cover prb makes me worried! any suggestion?
remove the battery cover and make sure you put it correctly also please take a picture so we can see the issue
Don't forget to mark the Correct Answers & Helpful Answers
for future reference
Make sure you backup everything
Settings -> privacy -> Back up my data and Automatic restore should be selected
and also
Use one of these links to download the
Backup & Restore app
http://forum.xda-developers.com/showthread.php?t=1193802
or
http://www.elita-clan.com/downloads/backup_and_restore_v010935.apk
http://www.elita-clan.com/downloads/backup_and_restore_v010935.apkor
http://www.mediafire.com/?1n07llajeaoo03y
How to install it
You need to
go to settings -> applications -> check unknown sources
download IO File Manager
https://market.android.com/details?id=org.openintents.filemanager&feature=search_result
download the backup & restore app, transfer it to your SD card, use OI file manager to find it -> tap on it -> install it
Contacts
just to play it safe sync your contacts w/ google if you haven't already
open your phonebook
press MENU button -> tap on Send Contacts -> select all -> send it to your email
on your computer
-> download the file -> go to your gmail -> click on contacts -> click on more actions -> on the drop down menu click on "import" -> choose the file -> and click import
Apps
Don't worry so much about backing up your apps
on your computer go to
market.android.com -> log in -> click on My Library -> and send all your apps to your phone
SMS/MMS
if you don't want to use the backup & restore app then
Install "backup SMS" to back up your SMS and MMS to your Gmail
https://market.android.com/details?id=com.zegoggles.smssync&feature=search_result
or your SMS use
"backup & restore SMS"
https://market.android.com/details?id=com.riteshsahu.SMSBackupRestore&feature=search_result
or for your MMS use "Save MMS"
https://market.android.com/details?id=com.schwimmer.android.mmsextract&feature=search_result
Call Logs
And for call logs this is great
https://market.android.com/details?id=com.yang.android.ansta
My Phone Explorer
https://market.android.com/details?id=com.fjsoft.myphoneexplorer.client&hl=en
An easier way to install the Backup & Restore app
download the apk on your computer, send it to yourself through email, make sure you send it to your Gmail
now on your phone
wait for the email, once you get the email, open it, and instead of downloading the attachment it will allow you to install it, voila, done
or
this is how to update
Update Service (SEUS)
http://dl-www.sonyericsson.com/cws/download/1/110/61/1309763183/Update_Service_Setup-2.11.7.13.exe
or if you prefer to manually update this is how
Xperia Arc LT15i/a 2.3.4 4.0.2.A.0.62
http://talk.sonyericsson.com/thread/29197
Yes, I removed the battery cover! I put it correctly. but it didn't work. this gap is not too large. but if I press my nail with little pressure then my nail can enter into this gap! I dont understand, is it manufacturing prb or not. becuz this phn is really very curve.
Can you take a picture, I have an Arc and like any other phone there's a tiny gap between the back cover and the housing, but I don't think its that big w/ my Arc, can you post a picture here?
I put a picture..please have a look!
that doesn't seem to be right, can you apply more pressure on that side?
if i apply more pressure on that side it goes in good level. But not being fixed itself!
I think you are putting it on the wrong way
here is how it should be done
http://dl-www.sonyericsson.com/cws/download/1/103/278/9/1321282683/LT18i__UG_EN_1253-8405_1.pdf
