Does someone have the camera issue? On 8MP auto, when you want to snap something in the dark with flash, sometimes a half of picture is black. It looks like saving picture is not synchronized with flash snap or some light messurement problem i don't know. I've checked all kind of variation in options - still no result. On 6MP everything works fine.
Ofcouse we speak about everything stock, locked bl.
Example
Here you have 6MP auto (everything ok) - http://i48.tinypic.com/2vjzbly.jpg
And here 8MP auto (bug) - http://i46.tinypic.com/17zuk5.jpg
Sony please check this
Solved! Go to Solution.
I'm too facing this problem but I as alternative I download app lgcamera through if u capture image with flash their will no dark area so you can download that app till sony announces new firmware
They should update our firmware. To Fix our Camera Etc.. Hey Sony!! Downgrade our Firmware
Yep. This app has workded well. Also the another app Zoomcamera is capured without any issues with 8MP with Flash.
Although any fix for notification sounds too?????
Same here, the cam bug isn't fixed yet so even I've downloaded the app, PuddingCamera, has anyone used it? Reviews please
Notification sounds---
change setting of viber, fb,fb msngr.
Change the sound from setting chose pre instal sounds for notification
Restart ur phone
I'm not facing any notification related essue after this step till now
Why so Quiet Sony? We are so annoyed by your epic fail update 😕
I think they will solve this issue with JB update...may be because of this bug JB update will come early..
Fortunately I came to this forum before updating my phone...Now cancelled it..
Hope..Sony is listening to everyone. Pls.. Sony guys ...need your attention for this...
HEY GUYS!! MY CAMERA STARTS TO WORK WELL! I WAS REALLY FRUSTRATED YESTERDAY SO WHAT I DID IS DO ALL THE BEST I CAN DO TO MAKE IT WORK.. I RESTARTED(NOT TURNING OFF) BY PRESSING THE LOCK BUTTON AND VOLUME UP BUTTON AT THE SAME TIME AFTER IT STARTED.. MY CAMERA STARTS TO WORK WELL IN TAKING UP 8MP PHOTOS AND COLOR REPRODUCTION SEEMS TO BE MUCH BETTER THAN IT USE TO BE BUT THE PROBLEM IN INSTAGRAM REMAINS AS WELL AS THE PROBLEM IN TIMESCAPE FACEBOOK INTEGRATION
Does not work for me though..I tried every thing. Reinstall Software.. Repair my Software.. Done a factory reset from my Mobile. But nothing works for me.. But lgcamera app is taking picures fine. But built-in cam is having bug. Also Instagram and timescape having problem.. Mr. SONY where are you hiding...
I like your name.Xperia really deserves that name.
