Does someone have the camera issue? On 8MP auto, when you want to snap something in the dark with flash, sometimes a half of picture is black. It looks like saving picture is not synchronized with flash snap or some light messurement problem i don't know. I've checked all kind of variation in options - still no result. On 6MP everything works fine.
Ofcouse we speak about everything stock, locked bl.
Example
Here you have 6MP auto (everything ok) - http://i48.tinypic.com/2vjzbly.jpg
And here 8MP auto (bug) - http://i46.tinypic.com/17zuk5.jpg
Sony please check this
Solved! Go to Solution.
im facing same problem after update.....plus quality of pic also reduce due fast processing of saving gallery.......
Me too having same problem, expecting a quick update fix from Sony.
same problem with me we need new update.....plus i cant use istragram camera to click in app just
You can use instagram, but when you take picture it only shows 1/4 of the screen the remaining 3/4 is dark. but when you capture photo. it doesn't have dark areas
Everyone..if u are rooted u can fix the camera by flashing this
http://forum.xda-developers.com/showthread.php?t=2026881
I was so annoyed by the bug tht i rooted and finally fixed it...
http://forum.xda-developers.com/showthread.php?t=2023756 shows how to root
hi! this problem has been fixed by the xda dev. visit this thread and do whatever it demands http://forum.xda-developers.com/showthread.php?t=2026881
this will work if you have rooted your phone or you have cwm installed on your phone:smileyhappy:
hope it helps you:smileyhappy:
I updated my Xperia P 30hours ago with this new firmware and 30hours of usage here is the list of fixed bugs and new bugs that I noticed.
Fixed bugs:
* Notification sounds are working fine after 30hours(earlier it wasn't working after few hours of reboot)
* Wi-Fi connectivity issue fixed
New Bugs:
* As all mentioned earlier the flash isn't covering all the captured region with 8MP camera resolution
* Still no improvement with battery (Even we didn't yet get the battery standby on ICS that we had on GB. But if we select GSM only on network then it last 2days)
I will check further issues and past here after 24hours again.
Still no update from Sony? DISAPPOINTING
I agree...this is really disappointing...
Okay. After usage of another 24hours looks like notification sounds are stopped working itself and this same issue addressed already on previous firmware. Don't why sony doesn't fix this simple issue yet
Also I noticed serious depth grip issue on this firmware. Sometime all the network bar has dropped and it showed "No Service" then after a minutes it back with 4-5bars
Urgent Bugs:
Camera with 8MP + Flash (new bug)
Notifications sound stopped working itself (Old bug still continue without fix)
