Xperia m5 Flashlight not working full power after marshmallow update
Sutheesh
Visitor
@Sony My xperia m5 flashlight is not working with full strength after marshmallow update when compared to lollipop.Kinsly check and povide an update
16 REPLIES 16
Didrik
Enthusiast
Hi @Sutheesh,
There is no setting in the phone to change the brightness for the flashlight. Is it just the flashlight or is it also the flash for the camera?
Sutheesh
Visitor
@Didrik I didn't ask any adjustment but the Flash is emiting low light oly it's looking like waste
Didrik
Enthusiast
If there is a notable difference compared to when you purchased your device I would recommend that you have an authorized service centre examine your device. In order to find information about local service and warranty procedures contact your Local support.
Sutheesh
Visitor
@Didrik : When i installed third party application from playstore it's emitting light with full power.I think so ther's some issue's in inbuilt flashlight application.
Didrik
Enthusiast
@Sutheesh,
If you want to make sure you can compare the flashlight in your phone with one from another Xperia M5. Should there not be any difference in strength then there isn't anything wrong with your device, if you however think there is something wrong with your phone I can only recommend you have it sent in to be examined by a technician.
Hello,
I've just updated my Xperia M5 E5603 to Android 6.0 as it appeared new update so I sayed "why not"... and of course problems...
I just noticed that after update my flashlight (this kindda thingy that you swipe from the top to down, somethings that look like this:
http://files.mgsm.pl/test/991/screenshot-2016-03-02-13-24-14-20696.png
The flashlight is under "Latarka" thing.
When  turn it on the flashlight seems to be working, I dunno, maybe on 30-40% of max power.
When I turn the camera on and capture photo in the dark, the flash/backlight is working on full power.
Somebody knows what is happening?
My phone's specs:
Xperia M5
E5603
Android 6.0 (now, before 5.1)
Comlication number: 30.2.A.0.110
Uliwooly
Contact your Local support to get it inspected
@DejvidPL wrote:
Hello,
My phone's specs:
Xperia M5
E5603
profile.country.RO.title
_alexdon_
@DejvidPL Now you are in the correct topic. Check suggestions here.
alexdon
Bob12
Visitor
I have the same problem, torch makes lower light than flash during camera. Is that a problem that sony have to solve with a minor update?
