Wrong Battery level reading?
Shub2
Hey Guys
I need your help.
When I'm charging my XPERIA M5, the battery level got stuck at level 83%.
The voltage is at max but the battery level stays at 83%
Maybe it's a software failure
Can somebody tell me how to solve the  problem??
1 RISPOSTA 1
profile.country.PH.title
MarlonUk1
does this happen when you are on safe mode?
a battery saving feature called charging optimisation is limiting the charge, try to see if this is active at settings>about phone
try to recalibrate your battery by draining it to 10% then charge with wallmount chrager
software repair using Xperia Companion
