Water resistant test
Tivi21
Visitor
Necesito saber como medir la presion en mi m4 aqua para ver si todavia es resisyente al agua
How can check if my Xperia M4 Aqua is still water resistant.
2 REPLIES 2
Uliwooly
@Tivi21
I've edited your post as this is an English only forum, you can use Google Translate to reply and/or post.
There's a test but I wouldn't rely on it, you should contact your Local support and request a vacuum test.
Emil
Enthusiast
Hi @Tivi21,
As @uliwooly suggested you should get in contact with your Local support team if you believe your device is in any way damaged and does not live up to its IP classification.
Let us know how it works out.
