Sound and music iss after marshmallow update...
SOLVED
VEER1
Visitor
After marshmallow update I am facing hiugh problem in music...
Music enhancement doesn't work properly a I am playing video in YouTube but sound enhancement not working in YouTube or all online music application... Right now I am feeling very sad...please Sony Xperia Inc fix it this issue...
Tags (1)
1 ACCEPTED SOLUTION
Accepted Solutions
cosmy
Visitor
Same here,even on Music app after MM the sound is low and from mid-line volume to maximum line is no differences. Xloud is insesizable , so low Slightly_frowning_Face hope Sony will fix this BIG issue
19 REPLIES 19
profile.country.PH.title
MarlonUk1
but does the enhancement work in the music app and or spotify?
try to clear data of the apps that are not responding to audio ehancement and restart your device.
sometimes updates to 3rd party apps will drop native enhancements in device to address some issues
cosmy
Visitor
VEER1
Visitor
Yes I am agree with you...
abhaydmahajan
Visitor
Audio output is low on YouTube after update and also device is heating up
Rapatel
Visitor
Same problem with me.
omnick
Visitor
Can you fix some software issue in my Xperia M4 aqua when playing music, some noise you hear in playing music app and the volume level from middle to full are the same but in playing video or youtube the sound are ok. I encountered this problem after software update from android lollipop to marsmallow, I also try to search to the internet according to my problem but he/she encourtered the same problem,.the tried also the software repair by using xperia companion but problem still occur.
omnick
Visitor
Also no sound in powering xperia m4 aqua.,
VEER1
Visitor
I am waiting for new update because I hope Sony will fix all issues in marshmallow...
VEER1
Visitor
Guys finely release a new update for Xperia m4 aqua build number is 26.3.B.1.33.
In this update fix all bug and performance issues.
