Sony Xperia M no signal - SIM works in other phones
Braddingo
Bezoeker
Hello.
I have recently had problems with my Sony Xperia M phone.
I recently dropped the phone and the screen had cracked and so i issued for a fix at a local shop and so i had to remove my sim card, sd card etc. As the phone returned to me i have not been able to have a signal however i get a very slight signal 5 minutes away from my home which makes no sense as i used to get full bar signal strength in my home before i took it in to get fixed.
I have searched for mobile network operators at home and it will not pick up any at all.
I have tried a factory reset; this did not work.
I have tried the Sony 'Update Service' and have also updated my phone to the latest version but nothing is working at all which is leaving me somewhat confused.
Heres what it says when i go to 'about phone':
Network: no service
Signal strength: 0dBm 99asu
Mobile network type: unknown
Service state: out of service
Roaming: not roaming
Mobile network state: disconnected
My phone number: unknown
IMEI: removed by alexdon - no private info on the forum
IMEI SV:
Also i have tried my sim card in my friends and parents phones and it works perfectly just like it used to. Also have tried their sim cards in my phone and they could not get a signal at all (the people were on my network also).
I'd appreciate help as i'm getting very frustrated.
Thanks.
15 ANTWOORDEN 15
Braddingo
Bezoeker
I do apologize i have the Sony Xperia M first version.
profile.country.RO.title
_alexdon_
Do you have the dual version?I think it might not been fixed correctly.
alexdon
Braddingo
Bezoeker
Sorry how do i check if its the dual version? my model number is: C1905
Braddingo
Bezoeker
Its just the regular Xperia M
_alexdon_
C2004/C2005.You have the normal version.You need to take your phone back to be checked:
http://www.sonymobile.com/global-en/support/contact-us/
alexdon
helllp1
Bezoeker
Hello,
I'm wondering if you can help. I have the Sony Experia M2 and the exact sae thing has happened to me - broken screen, got it fixed and now I continually have no service. It has come back for brief periods agin and then leaves, so frustrating!
I was wondering if you managed to overcome this and what you did? Would really appreciate any help you can offer.
Thanks so much. Slightly_smiling_Face
Eppy
suzy123
Bezoeker
Hi did you fix this problem, i have the exact same thing after replacing the screen in my sons phone. x
Chowdary007
Bezoeker
I got The Same Problem,that will be never repaired.Please don't buy Sony Phone
sandyerror
Bezoeker
Hi all,
Try this.
1) Go to setting.
2) In wireless and network section, select "More..."
3) Select "mobile network"
4) In that, choose "Preferred network mode"
5) Select "GSM Only" option.
And It's done.
