Problems to remove SD Carda nd Sim Card
acmerhej
Visitor
Hey, people!
I'm from Brzil and i've just bought my new M4 Aqua Dual. It's working perfectly, but the only complain i have about it is that it's impossible to remove de sd card or the sim card. They don't work like in other phones where you just need to pressfastly and it comes out of the compartment.
Does anyone have this same problem?
Thanks!!
11 REPLIES 11
Phy
Legend
Legend
This is how to insert and remove the SIM and SD cards
http://support.sonymobile.com/global-en/xperiam4aqua/userguide/Assembly/
acmerhej
Visitor
Hi, Phy!
The problem is not inserting the card but taking it off the compartment.
Thanks anyway
Phy
Legend
Legend
Click on the link and scroll down, you will find the steps on how to remove the SIM and SD cards
Phy
Legend
Legend
To remove the nano SIM card
Detach the nano SIM card slot cover.
Press the nano SIM card inwards until it makes a clicking sound and then release it immediately.
Draw the nano SIM card fully outwards and remove it.
Re-attach the cover.
To remove the memory card
Turn off the device and detach the memory card slot cover.
Press the memory card inwards and then release it immediately.
Draw the memory card fully outwards and remove it.
Remove the memory card from the slot and re-attach the cover.
Instead of turning off the device, you can leave it on and unmount the memory card under Settings by tapping Storage > Unmount SD card.
acmerhej
Visitor
I'm trying to do this, but the card doesn't make the "click"...it seems to be stuck, I don't know...I'll keep trying to do this or maybe go to the store gain...
Thanks
Phy
Legend
Legend
Perhaps you inserted the SD card backwards or the incorrect SIM card size.
Sinyo
Visitor
How long does it take to unmount sd card? Im afraid that if i do the turn off methode it will cause another problem in the future. Seem my device cant unmount the sdcard it took 5 minute or so but its notification that i can remove the sd card didnt show
Uliwooly
@Sinyo
What I would do is backup everything to a computer and reformat the SD card.
Sinyo
Visitor
And always buy new sd card? I do click "unmount sd card" but im not see "now you can remove sd card savely" after 5 minutes and that "unmount sd card" is still greyed out
