Problems in Xperia M2 lollipop update
Pas2
Visitor
There is a problem in photos after update.
Also some features are available only some regions(Tap and Play) it's not fair.
22 REPLIES 22
profile.country.US.title
Qatrium
There's a dedicated thread for Camera issues in M2 after Lollipop update, kindly use it instead of posting new threads:
/t5/Xperia-M2-M2-Aqua/Camera-image-looks-like-it-lacks-details/td-p/1043655
Beka1
Visitor
There is a problem after update of xperia m2 aqua, phone works slower at max brightness, on kitkat I didn't see that.
sanchezone
Visitor
Beside the problems with the camera and performance on max brightness, sometimes my device has problems with network connection, also once in a while i cannot turn on the WiFi. And when I'm listening to music and I turn off the display it's still active for about 1 sec. I mean, I can stop the music even if the display went off. You think Sony will fix it in some update or just leave it unfixed?
Pas2
Visitor
I hope Sony will solve that problem. Like they gave us lollipop.
Pas2
Visitor
After lollipop update, system aquired higher space in internal storage. So I had to move my all apps to Sd card.But once I upgrade a app it transfer to the internal storage automatically and shows message the internal storage is fill more than 75%.So I have to transfer all the time, when I upgrade a app. Hope it will be corrected by Sony from next update.
Pas2
Visitor
Sometimes watch is not display correctly. Why?
Pas2
Visitor
But I haven't faced problems (regarding Wifi and music) that you mentioned, in my Xperia M2 after lollipop update.
Koruske
Visitor
My problems in the lollipop thing:
*Internal storage got higher like its saying 75% higher. Where in kitkat last time its only 40%+. It's a big difference!!
*The brightness sometimes suddenly gets brighter, though I adjust it already. Its a bug.
* and the camera also...
Please fix this. Or just go back to being Kitkat, where there is less problem.
