Even though I have nfc turned off I keep getting a message on my screen saying not enough memory change your services. What can I do to fix this. I don't want NFC on I just want to stop the message coming up Thanks
Hi @1408,
I'm sorry to hear this.
Would you be able to provide a screenshot of the message you are receiving on your device? You can take a screenshot by holding down the power key on the side of your device then tapping Take screenshot on your display. I'm not quite sure what error message you are receiving so it would be helpful to see the exact message.
I do recommend that you try to reboot your device to safe mode to rule out that this behavior may be caused by one of your downloaded apps as these will be temporarily disabled in this mode.
Let me know how it goes!
