M5 wont power on
Yalcın3007
Visitor
M5 wont power on
Telefonum su geçirdi ve açılmıyor bir web sitesinden almıstım ne yapmalıyım
My phone has water and does not open What I have to do is from a website
1 REPLY 1
Uliwooly
@Yalcın3007
I've edited your post as this is an English only forum, you can use Google Translate to reply and/or post.
Are you saying that your phone was exposed to water and it's not responding? if so, remove the sim and SD cards > place the phone in a bag with rice for 24-48 hrs > also contact your Local support
