Sony Xperia Companion
SOLVED
Thomas301
Member
When I try to backup my phone to Google I get the attached error message.
26 REPLIES 26
Thomas301
Member
I have tried backing up my phone to my computer with Sony Xperia companion but get the enclosed screen messages. I restarted my phone but still get error messages.
Phone Backup Communication failed screenshot..jpgPhone Backup error screenshot.jpg
Anonymous
Not applicable
Can you try to transfer the data to the computer without using Xperia Companion until you reset the device?
Thomas301
Member
How do I do this?.
Anonymous
Not applicable
Try these steps and check:
To back up files to your computer
  1. ​Unlock the screen of the phone and connect it to a computer with a USB cable.
  2. On your phone: if prompted to Allow access, tap Allow.
  3. On your phone: drag down the status bar, then tap Android system next to (USB icon) > Tap for more options > File transfer. This will allow the computer to detect your phone.
  4. On your computer: open File Explorer and find and select which files to back up from your phone.
  5. On your computer: copy/paste or drag and drop the files to a location on your computer.
Thomas301
Member
I've done this but still can't sign into my google account from Sony Xperia companion or from my phone to backup files to my google account. I still get the same error message as above.
Anonymous
Not applicable
Yeah, that's why you need to perform factory data reset to solve the issue with the Google account on your device.
Thomas301
Member
I can't connect to my google account on my device even after performing a factory restore.
Anonymous
Not applicable
Do you still get the same error message after the factory data reset?
Thomas301
Member
Yes I do.
Anonymous
Not applicable
Can you try the exact instructions in this link to perform software repair without asking you about the Google account thing?
https://bit.ly/3whYBZ8
