UBP-X700 Home Screen and menus blurry on 4K tv
Flipmartian
The Home Screen and menus etc on my new UBP-X700 Blu-ray player are not sharp and crisp like I  would have expected for a 4K device. It looks awful and fuzzy like it’s upscaled a lot.
The X700 appears to play a 4K Blu-ray at 2160p on my LG C2 OLED correctly.  However, pressing a button on the x700 remote while the disk is playing brings up a really nasty looking fuzzy menu. Like it is superimposing a low-res menu on top.
i have another Sony device plugged into the same TV…  an HT-A9 sound system. When I view the Home Screen on that and go through the menus,  it is all pin sharp. I can’t understand why this Blu-ray player is not the same level of sharpness.
Are the X700 menus and Home Screen meant to look this bad?
Tag (1)
1 RISPOSTA 1
HannahEd01
Hey Flipmartian, could you share pics from both menus, so we can see it?
Also, are you using a high-speed HDMI cable? Did you try restarting everything?
