Hi, I have a RDR-HCD860 which I have used for many years with no issue. Recently discovered that my recording to the HDD are of a poor quality for BBC1 and BBC2 due to the fact that there are now channels 836/7 that are also BBC1 and BBC2.
I tend to record a series from the EPG and record on 001, I see a red circle with a clock symbol - no issue. If I then scroll up the EPG for the same program, I see another red circle with a S inside. When the program records it sometimes records on 836 and sometimes on 001.
I have tried to delete the series and re-create, but still see the red circle with the S on 836.
Can I delete 836/7 or....?
Many thanks for any suggestions
Regards, Paul
P.S. Strictly has started so wife is not happy ![:slight_frown: :slight_frown:](/html/@9F65865CACF789EA70239425DDDA9A29/images/smilies/035.png)
