- Mark as New
- Bookmark
- Subscribe
- Mute
- Subscribe to RSS Feed
- Highlight
As the BDP-S4100 sadly lacks phono output sockets, is there any way of connecting it to my Schneider home cinema surround sound speaker system which only has phono inputs? Is there an HDMI adapter which breaks out a pair of phono leads? (The Schneider came with a SCART lead with breakouts for the older TV connectors - It's old I know but it still works well and I don't wish to have to buy new just for the sake of a lead change)
My older BDP-S350 had phono outputs, so I might have to keep that as well just so I can play with good sound.
Solved! Go to Solution.
Accepted Solutions
- Mark as New
- Bookmark
- Subscribe
- Mute
- Highlight
Something like: http://www.amazon.co.uk/Digital-Optical-Coaxial-Toslink-Converter-Analog-RCA-Audio/dp/B0074JZ8ZW
- Mark as New
- Bookmark
- Subscribe
- Mute
- Highlight
Hi there
Have you had a look at something like:
http://www.amazon.co.uk/Mini-Composite-Video-Audio-Converter/dp/B00BUQOQCG/
However you are also feeding video via the composite connections too, and therefore will loose the benefits of Bluray (HD).
For a component converter, try:
http://www.amazon.co.uk/Neet%C2%AE-Component-Converter-Supports-Lifetime/dp/B002C7CCJ6/
Cheers
- Mark as New
- Bookmark
- Subscribe
- Mute
- Highlight
- Mark as New
- Bookmark
- Subscribe
- Mute
- Highlight
- Mark as New
- Bookmark
- Subscribe
- Mute
- Highlight
