Hi all
I am creating a break-away thread/topic that lists all of the potential solutions either officially from Sony or the Community itself.
This thread will be locked for replies, so please reply back in the main thread, located :
Many of you have also asked why is there no "ON" switch like other models have. According to Sony, "This is to comply with EU regulations. If ON is the constant standby power consumption would be too high."
Thank you
If the above information from the manual does not work. Sony recommends that you turn OFF the HDMI Control setting on the AV Receiver itself.
To do so, goto theh "HDMI Settings" menu, then goto "Control for HDMI" and set this to "OFF"
According to one of our Community Members (MK_Slinky in the post HERE) the following may also assist :
Try this in this order:
In the manual for the STR-DN1040 it advices powering down and un-plugging the system before making any connections. Ultimately doing so would be the same as having a power failure, It could be that those who've experienced this issue just need to reset Pass Through OFF then to AUTO again.
According to one of our Community Members (glowworm in the post HERE), the following worked on his KDL-40HX803 TV:
TV Settings:
AV Receiver Settings:
Again, this information comes courtesy of a Community Member "MK_Slinky" in the following post : HERE
According to the manuals of Panasonic TVs, it states the following:
On the Panasonic Viera TVs, do the following:
