Wifi - iTunes to CMT-G2BNiP
profile.country.en_GB.title
acatswhisker
Visitor
I seem to have good wifi access to all of my laptops and PCs, but I have two problems:
1 - When I view the artists in iTunes it gets part way down the 'Bs' and then reveals no more.  How do I get to see (and play) the C to Zs?
  • :slight_smile: Actually just solved this myself - I was using a none standard location to store my iTunes and, having moved it back the system now sees all tracks, but the problem below is still not solved.
2 - When I scroll down to the playlists it is not finding any that are currently stored in my iTunes.  How do I get to see (and play) them or re-create them so that I can?  It does fine one call unknown with no tracks in it.
Message was edited by: acatswhisker
0 REPLIES 0
