Sony Sound bar CT60BT not turning on, remote is working fine, is there a fix?
drrnong
New
Just got got the soundbar a few days and it started to give out. It was working a few hours ago but now it doesnt work anymore, reconnect the power lead and its still not working.
5 REPLIES 5
profile.country.RO.title
cosmingpx8
Member
Hello verify power supply.Or fuse in the power supply .
drrnong
New
Hi cosmingpx8,
Thanks for answering, but I tried changing the fuse and made sure the power supply is properly connected. It still didnt work.
Thanks
cosmingpx8
Member
Hello verify if you have not broken the PCB tracks, processor, remote sensor.
drrnong
New
I'm having a friend look at it, so will come back and say what's wrong with it.
Thanks
JKearnes
New
Hi,
Did you find a solution to this? As I seem to be suffering from the same problem. Was working one morning then just cut out entirely. No power lights on and have checked the fuse.
Thanks
