micro sd problems are doing my nut plz help
profile.country.en_GB.title
wicky92
Visitor
hi
     about 6 months ago i bought a 32gb sony (obviosly) micro sd card.
ever since i've had it i have had problems with it randomly corrupting and nothing i try seems to remedy this ive formatted it countless times, tried it in different devices to no avail hope someone can point me in the right direction
          cheers
1 REPLY 1
StartTheCar
Contributor
Hi wicky92
As with any product, if you feel it’s not 100% right or even faulty, my first port of call would be the supplying retailer.  While it’s impossible for me to be sure, my experience with Sony cards has always been very good with no problems like the ones you describe.
Regards
Lee
