Memory card for Sony dslr a200
SOLVED
Jackal38
New
Where can I source memory card for dslr a200 believe it has to be a compact flash cf1 or cf2 it appears no other card is suitable for this age of camera . Thank you
1 ACCEPTED SOLUTION
Accepted Solutions
jan2011
Enthusiast
Hi
You can use:
---CompactFlash card
---Microdrive
---MemoryStick Duo (using a MemoryStick Duo Adaptor for Compact Flash Slot: http://www.sony.co.uk/support/en/product/AD-MSCF1 )
( More info on pag.21-24 http://download.sony-europe.com/pub/manuals/consumer/DSLRA200EN.pdf )
-MemoryStick Pro Duo
-MemoryStick Pro-HG Duo
Cheers
Jannis
PS. Example AD-MSCF1:
http://www.amazon.co.uk/s/ref=nb_sb_noss/279-8437014-9318455?url=search-alias%3Daps&field-keywords=A...
4 REPLIES 4
Blencogo
Hi Jackal38 and welcome.
The A200 can use Compact Flash media or MemoryStick Duo with an adapter.  This is copied from the specifications for that model: -
Compact Flash Type I / II / MicroDrive slot. Memory Stick Duo / MS Pro Duo and MS-PRO HG with optional adaptor
Both Compact Flash and Memory Stick Duo are readily available from almost any camera shop - Jessops/Dixons/Currys/Maplin or online from Amazon or eBay.
If you use MemoryStick Duo you need the optional adapter: -
http://www.ebay.co.uk/itm/Sony-AD-MSCF1-Pro-Duo-Memory-Stick-Adaptor-/251493495155?pt=UK_Photography...
:wink:
jan2011
Enthusiast
Hi
You can use:
---Microdrive
Cheers
Jannis
Jackal38
New
Thank you Jannis very helpful this should rectify my problem again many thanks ,kind regards    jack
jan2011
Enthusiast
Hi Jack. You’re welcome! :slight_smile:
Cheers  :wave:
Jannis
