I would like to know the last firmware up date for the DVD player BDP S350 please.
I recently found that my S350 will no longer play a few discs. I can't be sure, but it may have been following the upgrade to the latest (024) firmware.
The discs are not damaged in any visible way and don't need cleaning. They worked fine one day then the next they don't.
I've checked Serenity and it plays OK in my S350 with the v24 firmware.
I did contact Sony over a week ago. They seem to be scratching their heads on this one.
I tried a fourth Universal disc: Back to the Future. Exact same!
this man says ribbon maybe weak solder maybe,
This person's saying clean the Laser, others say it is worn out, others say they do not wear out.
At 91 years old I done in by all this, too exhausting for me. Ordering Panasonic BD84, or similar.
The S350 is few years old now - 2008 by the look of it, so at 12 years old any repair is likely to be uneconomic. You're better off just buying a new unit - and if you just want a basic player the Panasonic BD84 is about £ 60 on line and will do the job just fine.
I have a DVD lens cleaner but it won't work on it so have ordered a Blu-ray one specifically.
https://forums.digitalspy.com/discussion/2374591/blu-ray-player-not-working
