Reader Library software not showing books
profile.country.en_GB.title
Enigma2012
Hello,
I purchased a PRS-350 last week and setup all the software and all was working great, however today when I opened the library it will not show any books or the far right options ( IE computer, reader, books ect)
See the screenshot below.
The reader sounds like it has connected to my laptop correctly as I get a noise when plugged in.
Any ideas?
Message was edited by: Enigma2012
2 RISPOSTE 2
selbramdrol
I have exactly the same problem - except I have had my reader for 18 months with no problems before.I thought I would be clever and uninstall and reinstall Reader Library and it won't even install now so I have nothing.
carpetmojo
That all looks very strange - don't recognise that at all !
Have yiou done a soft re-set ? It often performs miracles....
But, in case it don't....
I suggest - providing you just want to get going again, and give up, for now, on the books you have - install Calibre and use that .
You won't need reader, and is the bee's knees. A great - in fact the best - ebook management system.
Just buy/download books, but when the option comes to "open using reader", select other button, "save to file".
Then it will d/load and show on your Downloads panel, and you just rt click ,"Open containing folder", click,  and Drag 'n drop high-lighted file into the Calibre library area.  Done.
You can re-address the Reader prob's later, but at least you can use the reader .
