wifi problem
Kulwant
wifi problem
c1504 . It does not connect to my home WiFi network automatically. It connects when it wants to connect and not when I want to connect .
I have tried  everything from rebooting the phone to restarting the wifi hot spot, but the problem come back again. the wifi connection is not consistent. I have even tried repairing the software via sony pc companion.
I  must add here that sony Xperia E is the worst android phone I have come across. I have been using Samsung Galaxy Y for 2 years and I have never faced such problems with that phone.
Kulwant
fortunately my seller agreed to take back my used Sony xperia E . and I used the retured money to buy SAMSUNG S Duos. It is working fine now .
You can also save yourself from frustration by selling it away, thats the only way. otherwise write to sony for a software upgrade, If hey will listen to you.
8 RISPOSTE 8
xperiaEman
"i know ,moving from samsung to sony has never had good results....... but .......we have to MAKE . BELIEVE in sony"
does it connect manually ? [through settings]
Kulwant
when it doesn't want to connect, it doesn't connect even manually. forgive me but I cannot believe in SONY for no reason.My seller has agreed to take it back today. I could have believed in SONY if it performed according to my expectations.
AravindAchu
My Xperia e connects easily to wifi.....but it always faces a connection problem.....so im not able to enjoy facebook or any other social media services bcoz of this problen....plz help me....thanks in advance.....
Kulwant
osk
Wifi works fine :smileysmileywink:
factualstory
My router is d-link and works well with samsung s2 but the Z1 connects to it at very slow pace as if it was on dial up internet ! what kind of router do you have ?
factualstory
Re: xperia z1 wifi issue Options a moment ago My about 8 day old Z1 Xperia is very slow on my wifi network......my older model S2 which I upgraded from to Z1 is more than twice as fast as the Z1 !!!! However, the Z1 1 is faster in date internet than it is on local wifi ! Sony support are not telling me if the slowness is in the design of the z1 wi-fi or if its a settings problem. I think its a wifi design problem as I tried all kinds of settings even ones given to me by sony support and none have helped. Yet being a new phone Virgin are refusing to give me a different model handset saying they would replace it with the same Z1 ! Whats the point of that the same fault would be in the exchange unit !
Kulwant
I have an ASUS N10 E wifi router
