How do a block a number on my E2105 sony
Hi @Joeven, welcome to our forum!
There is no setting in the Xperia E4 to completely block a number from calling you, but there are some options.
You can either download an application from the Google Play store that you can use to block a number from calling you or you can save the number as a contact and send all incoming calls directly to your voice mail.
To do that, open up the Contacts application and create a new contact based on the number you want to "block" > after you have entered a name and number, tap the 3 dots in the top right corner and tap on the little box next to "Send all calls to voice mail".
I hope that helps!
Thank so much, I have been sweating for nothing thinking "M daffed"
@Joeven, you're very welcome!
Let me know if there is anything else and have a nice day.
