Need to identify replacement cable for DSC-HX100
Trilmr20
New
I have a Cyber shot DSC HX-100.  I don't think it is a compact camera but that was the closest subject listed for a board.  I need to purchase a replacement cable - the cable that connects the camera to my computer so I can download images.  It may be a HDMI but I cannot see the diagram clearly so am not sure if that is the correct cable or maybe it is the Type 3c multi-connector?  Can someone help me id the cable?  And, if you know where I can get it that would be wonderful!  THANKS!!
Tags (1)
1 REPLY 1
profile.country.DE.title
IamNic
Hello @Trilmr20,
while the port is a so called "MULTI"-port, the cable used to connect the camera to your PC is a normal micro-USB-cable with data-transfer capabilities (usually all are).
You probably have a few of them lying around (at least I have) from e.g. a smartphone or other devices.
- Nic
