Sony HDR CX240 SD Card size and speed?
profile.country.IE.title
andy_from_sligo
Explorer
hello I am looking at a 64gb micro SD card 80mbps - would it work OK in my Sony HDR CX240 ?
thanks - I wont be fiming at the very top high quality setting, the next one down i will be
1 REPLY 1
profile.country.DE.title
IamNic
Hello @andy_from_sligo,
according to the specsheet the bitrate (data rate) on the camcorder during a recording in the best possible quality is 28Mbit/s (3,5MB/s) so a 80MB/s writespeed card is roughly 22 as fast as needed.
I personally don't see any reason why the card you choose wouldn't work.
- Nic
