I own a sony handycam dvd110e camcorder , it records alright indoors but as soon as i try to record outside in daylight it just records white , it is showing red eye reduction but i have tryed everything to remove it, i have looked on the menu options for white light option but it is not showing, can this be repaired or do i need to purchase a new one or can i start over again by deleting everything, i am using a memory stick for recording, any help appreciated
Hi there,
Hopefully one of the community members has had some experience with this, and can help.
Best wishes,
M
Hi Vicstu08,
I'd recommend resetting all settings using the reset button as explained on page 129 of the Manual available through this link: https://www.sony.co.uk/electronics/support/res/manuals/3285/32853671M.pdf
Cheers,
The_Black_Rose
