Sony FDR-AX700 viewfinder
radeaco
Explorer
I have just bought a new FD-AX700 and found the image in the viewfinder and LCD display to be very dark. I have been through all the help document but didn't spot an option to brighten the viewfinder, while there is one for the LCD. Has anyone else found this and did you manage to resolve it? Thanks for your help. Ray.
3 REPLIES 3
Joe_Dohn
Specialist
The Viewfinder doesn't have brightness adjustment. Have you tried this?
radeaco
Explorer
Hi Joe,
Yes I tried that adjustment and fitted the rubber cup. It still appears much darker than the monitor but I guess I'll get used to it.
Thank you for taking the trouble to reply.
Kind regards.
Ray
HannahEd01
Hi radeaco, have you tried cleaning it?
