Hi,
I have a Sony HD handycam- HDR-CX115E. I have only used it a couple of times in the two years I've had it but it was great. Today I got it out to take on my big/ exciting trip to Oz and the screen is red and so fuzzy that it is difficult to see anything. The screen hardly changes whether the lens cover is open or not. So it is currently unusable. The pics and videos that are saved on there remain viewable and very clear. Have I knocked a setting to cause this or is there a problem with the handycam itself? Advice would be greatly appreciated
Many thanks
Kara
Solved! Go to Solution.
Does not sound good I am afraid, if older footage is fine but new recordings are fuzzy and have a colour cast then it does seem it will need to be looked at by the Sony Service Centre. Not sure what could be wrong here but I am unable to see anything in the settings to help fix this.
Regards
Teshi
Hi @patalford and welcome to the Community
There is a reset button available on your camcorder.
You just have to press it with a pointed object
Have a look here
for more details
Cheers
Hi Kara
If you find that the end video footage once transferred is fine but the screen is "fuzzy" there could be one of two things, the screen itself is not exactly high resolution like you get with most phones etc since it is there to only display what you plan to record but it should be clear enough to make out everything.
The most likely reason is going to be that there is some sort of problem especially if the entire screen has a red hue over it. I would say something like that would be need to be looked at by the service centre.
Hi,
Thanks for your reply. The difficulty isn't solely with the screen unfortunately. It must be a problem with the lens because it records really fuzzy with a red hue too. Only old videos play clearly as they should.. Do you think it definitely needs to go into a sony centre?
Regards
Kara
Regards
Teshi
Same problem.
Messed around with the focus on a manual setting.
Then played around with the W and T setting on top of the camcorder.
Now its fine.
All these gadgets should have a restart to factory settings especially for ameteurs like me.
Have a look here
for more details
Cheers
