Hello there!
I would like to achieve very slow & consistent long zooming shots. Since that is quite a random matter with the power zoom lever I'm looking for external remote control. I found the RM-VPR1, but I'm not sure if there is any control over the zoom speed. What do other AX-53 owners use?
Cheers,
D.
Hi @dragra
A similar question has been asked before, please see the following thread: https://community.sony.co.uk/t5/camcorders/fdr-ax53-remote-control/m-p/2364485#M4314
I am unable to advise on the RM-VPR1 but the above may help, there is more than one way to skin a cat !
Regards
Hi @Jonnie1266,
thanks for trying to help. I know about the WiFi app option mentioned in the link, unfortunately it's is only 1 zoom speed available there which can not be modified.
I want to zoom very slow & consistent, this is difficuld to achieve with the power zoom lever on the camera itself. That's why I want an external controller solution.
Cheers,
D.
You are welcome, and I agree, the zoom can be haphazard at best !
Regards
