Hi plaice,
I'm just going to try to find some answers for you. In the meantime, maybe someone else in the community might have some ideas.
Thanks,
Pascale
It could be a fault but have you tried moving the Viewfinder adjustment lever?
Pull the viewfinder up as far as possible and look on the underside of the viewfinder. There is a small lever to adjust the focus for different eyesight requirements.
See Manual Page 27
https://www.sony.co.uk/electronics/support/res/manuals/3065/30656461M.pdf
If that doesn’t help a repair may be needed.
Hi tried the viewfinder also Zoom in and out still no joy. When you look into the viewfinder it is like looking at a negative but blured not sharp.
Thank you Pascale_F
Thanks Blencogo
