Hi all,
I bought X950G and been using Samsung soundbar. The sound bar is connected through HDMI cable but the problem is that I am unable to use the TV remote to control the sound Bar on Samsung speaker. Am I missing out on something?
PS: I have tried connecting it through HDMI and optical cable without any luck.
Hi there,
Welcome to the Sony Community.
I'd recommend getting in touch with the Sony Support team here who will be best to advise if this is possible.
Best wishes,
Sean
You are missing to tell us which soundbar model you have and so which connection it supports....
