I have a XF9005 with a Sony Soundbar CT380. I understand the soundbar is not working correctly through the Ark socket. I need to replace this unit and note the same model isn't avavailable in the UK. I have seen the CT290 soundbar. Would this match/be compatible?
Grateful for assistance, thank you
Mike
Connect to your TV over a single cable with HDMI ARC
So electronically, it looks promising.
Aesthetically we will have to leave up to you.
Thank you for your reply.
I note the sound bar does have lip-sync problems. If using an opitical cable as well will this help?
Thx
Mike
