Sound System HT-XT100
kensmyth
I have a HT-XT100 Home Theatre System and my TV is KD49X8005C. Before the latest updates everything was working fine, but since the update it will not turn on when the TV is switch on, and I can’t control the sound from the remote control.
I have used the Bravia Sync, but the TV does not find the sound system. I have changed the HDMI lead still nothing. I have returned the TV to factory settings tried with the sound system, but it won’t reset to factory.
I have been through both user manuals and have no idea,
1 RISPOSTA 1
Mick_D
Moderator
Hi @kensmyth
Have a look through this 'how to'  guide, to make sure you've covered all bases.
Hopefully something there will fix it?
Mick
