Hi @jabriall
You need to enable the IR repeater function on your sound bar. Have a look at page 17 of your manual.
https://www.sony.co.uk/electronics/support/res/manuals/4727/47274142M.pdf
Hi @jabriall
Thanks very much. It works without problems. I wouldn't have located that page of the manual if you hadn't pointed me at it. It's simple when you know how,
Thanks again.
