Hi
The remote for my Sony 49” 2019 LED TV doesn’t function. (RMF TX310E) I bought a replacement and that doesn’t work either. No response from any of buttons, unable to switch from Sky Q hdmi to TV. Firestick etc.
I’ve done soft reset and TV comes back on but unable to use remote.
Tried multiple new batteries.
Thanks
@SteveStacey wrote:“Far enough away to show the entire end”. Can you explain this please. Thanks.
Hi @SteveStacey I'm starting to believe that this is just a wind up ... over and out.
No wind up mate. I don’t think the remotes (either of them) are sending a signal.
I’ve also tried the Sony remote app, but this requires access to remote to set it up. You couldn’t make it up.
Works now. Thanks for your advice.
