Sony KD55XE9305 (HDR)
ninja_geezer
Explorer
Hi all just got a KD55XE9305 tv ,one thing i cant seem to get my head around is the HDR, if im watching something using HDR why dont i a see a popup telling me its active like my buddys LG or am i missing something.
ive tried pressing the info button but it shows nothing..for instance i bought a movie from the playstore but i cannot get any info when its playing. or streaming a film from my pc ?
9 REPLIES 9
EdwinaU
Moderator
Hi Ninja,
Welcome to the community.
There's an online guide for your TV here with manuals that should help you find out more about how the HDR display features.
Cheers,
EdwinaU
ninja_geezer
Explorer
ive got the manuals nothing in this of use thanks anyway.
Drewde
Administrator
Hi,
Are you sure the move your watching supports HDR?
Thanks,
Drew
ninja_geezer
Explorer
Hi yes someone has told me how to check.
click on the action menu during playback and go to picture if the hdr box is on then we are good...
bittihuduga
Explorer
yes, it works.
when i am watching netflix hdr, i press action menu->picture-> on the screen it says App HDR.
although i cant get the same when I am watching kodi or vlc as it stops movie being played.
ninja_geezer
Explorer
@bittihuduga wrote:
yes, it works.
im watching a film streamed from my pc via nvidia shield ,using  SPMC (Kodi) works the same for me .
romipat
Member
I   downloaded a  test hdr  sample  onto a  usb  an I also expected  a pop  up to say that it had detected hdr content and  therefopre switched to  optimum settings for hdr media. So are you saying that  you oly seea  notofication  of hdr content if yo  go  into the  action menue/picture section ?
ninja_geezer
Explorer
Yes that is correct.:wink:
romipat
Member
thanks  for   clarifying that.
