Sony BRAVIA KD-55XE8577 Beeping every 26 seconds
yeksk1
Recently I noticed that the BRAVIA TV is generating a beep sound over the speakers at every 26 seconds.
Anyone know the reasons?
Thanks
SK
6 RISPOSTE 6
Anonymous
Non applicabile
Hi there,
Have you tried a factory reset?
Best wishes,
M
yeksk1
I did reset the audio. but not the everything.
Besides that I updated to Oreo, didn't help.
I tried with HT-ZF9, HDMI or optional out. Same beep heard.
EdwinaU
Moderator
Hi Yeksk1,
Thanks for getting back to us. We'll look into this and let you know what we find.
Maybe some other members will have some advice too.
Best wishes,
Ed
yeksk1
Tenneen9000
Hi Yeksk1,
That's disconcerting. I'd recommend narrowing down the list of suspects causing this beeping sound by removing external devices one by one, and eventually factory resetting the TV. Do let us know the outcome though.
Cheers,
Tenneen9000
yeksk1
After much efforts, I found out that one of the installed App had caused the problem. I killed the process, beep sound had gone.
