I've been looking for what feels like ages trying to find a solution to what seems like a simple problem. My Sony TV on turn on simply comes up with the android loading screen then freezes and turns off again. The TV will then turn its self on again and will repeat the same process. I've tried to do a factory reset but I don't think the TV will stay on long enough to allow me to do one. I've emailed Sony and yet to get a reply. Any help would be appreciated, I believe it may need a new av board/main board. Very frustrating for a TV that costs 400 quid +
Hi Ewan,
Welcome to the Sony Community.
Can you try completing the following steps here.
Let me know if this resolves the issue for you?
Best wishes,
Sean
