Hi,when i first installed my tv and enable Google Assistant everything was working normally and the orange blue led was on when the tv was on standy,enabling me to use Handsfree voice commands on standy.However my dad changed the language to Bulgarian,disabling the voice commands,i switched back to English language,enabled the voice commands but the build in mic no longer works on standy and is not illuminating orange when tv is off.
How to enable the standby voice commands again?
Solved! Go to Solution.
Have you simply tried to restart Android TV by holding down the Power button on the remote control?
Thank you it works!
You're welcome...
