Sony Android TV Remote Control...MOUSE.apk Suggestions.
gcac2828
Member
There are some Mouse Toggle APK's available for Android Boxes but these don't appear to work with the TV Remote when installed on our SONY 43XE8005.
Any feedback suggestions please.
5 REPLIES 5
EdwinaU
Moderator
Hi there,
We'll take at look and let you know what we find out.
Maybe another member will also have some information to share.
Best wishes,
Ed
gcac2828
Member
 Your reply appreciated.  A much earlier OS version , can't recall the version but I remember being able to...Double click the Play or Porse to activate / disable a mouse.
gcac2828
Member
I searched in Google Browser....I have downloaded a Mouse Toggle for Android TV v1.52. APK
Following the supplied instruction after install works OK.
Tenneen9000
Member
Hi gcac2828,
I was going to suggest this article on the Sony support website that basically says that most mice and keyboards should work with Android TVs. However, I can see that you've already figured out how to get the apk to work properly on your TV.
Cheers,
Tenneen9000
gcac2828
Member
Tenneen9000. Yes, thank you but appreciate your reply.
