I cant update to Android Oreo 8.0. Why? Have they delayed it? Bug?
And some apps dont shows up, for example HBO, i have to search for it to start it. Bug?
@hitta_jonte wrote:I cant update to Android Oreo 8.0. Why? Have they delayed it? Bug?
Hi @hitta_jonte
You should find the explanation of why no Android Oreo on your product support page. You can update manually at your own risk if you like.
https://www.sony.co.uk/electronics/support/televisions-projectors-lcd-tvs-android-/kd-55xf8505
A quick search of the forum for HBO should answer your second question.
Sorry, did not find anything about it. Only that they stop the release in februari. I read yesterday that a new update will come out in late april but i did not got it yet. Anyone else?
