rmt-tx100d remote control buttons
SOLVED
Will_cain
Member
Easy Question, not that I can find an answer, but does anyone know where a description of the button functions on a RMT-TX100D remorte control is.
Cheers
1 ACCEPTED SOLUTION
Accepted Solutions
profile.country.HR.title
kinggo01
Contributor
4 REPLIES 4
Anonymous
Not applicable
Hi there
Which model TV have you got?  The description of the remote control buttons is usually in the reference guide for your TV.
Cheers
kinggo01
Contributor
remote page 10 and 11
Will_cain
Member
thanks, I looked through the user manuals and couldnt find this. Where does it live, the link downloads the PDF so i cant spot it.
Thanks again
Anonymous
Not applicable
Hi there
Search and select your TV model from this link:
http://www.sony.co.uk/support/en/series/prd-tvhc-tv-lcd
And then select the link "view all available manuals"
Cheers
