- Mark as New
- Bookmark
- Subscribe
- Mute
- Subscribe to RSS Feed
- Highlight
Hi!
I lost voice from all of my apps from the tv suddenly couple of weeks ago and I'm all out of ideas, hopefully you guys can help me. So my setup is Sony KD-55X8505C TV and Yamaha RX-V779 receiver. I have all HDMI cables hooked up to the receiver and only one goes to the TV's HDMI ARC -port.
All has been working fine for couple of years until suddenly the sound from the apps in the tv it stopped working couple of weeks ago. Chromecast, Xbox etc. sound works fine, only problem is with the apps. I have checked the connections, factory reset the tv and checked for an update (no Oreo update on my tv which had the same issues). Is there something else that I can try, before taking the tv off from the wall and change the HDMI cable? I don't that the problem is in the cable, because the picture works fine.
Thanks!
Solved! Go to Solution.
Accepted Solutions
- Mark as New
- Bookmark
- Subscribe
- Mute
- Highlight
Hi,
That sounds weird! Have you tried removing all devices and just test if the TV will output the sound from these apps? You might also consider unplugging the TV from the mains for a while and replug it back just to refresh it.
Vanilla_
- Mark as New
- Bookmark
- Subscribe
- Mute
- Highlight
Hi there,
Have you tried performing a Clear Data or Cache from External Input Services Application on your TV?
To do this please follow the steps below -
- Press the HOME button on the remote.
- Select Settings.
- Under the TV category, select Apps.
- Select System apps.
- Select External Input Services.
- Select Clear data and choose OK.
- Select Clear cache and choose OK.
Let me know how you get on?
Best wishes,
Sean Mc
- Mark as New
- Bookmark
- Subscribe
- Mute
- Highlight
Thanks for reply,
didn't help unfortunately.
- Mark as New
- Bookmark
- Subscribe
- Mute
- Highlight
- Mark as New
- Bookmark
- Subscribe
- Mute
- Highlight
Hi,
I don't know what the problem was, but I unplugged everything again from the amp and the sound came back! Hopefully doesn't happen again soon, thanks all for help!
- Mark as New
- Bookmark
- Subscribe
- Mute
- Highlight
Hi J11J11,
That's fantastic! Thanks for sharing this with us.
Have a great day ahead!
Vanilla_
