my sony Bravia KD55XD8599 does not have amazon alexa ap installed
seashore68
New
1 REPLY 1
https://www.sony.co.uk/electronics/support/articles/00186768
Supported TV models
Supported models have the TV Control Setup with Amazon Alexa app on the Home screen. You do not manually install this app, it will automatically install on supported TVs. If the app is not on the home screen, your TV may not be supported yet. Make sure your TV is set to automatically receive updates.
2016 Android TVs
  • XD70, XD75, XD80, SD80, XD83 and ZD9 Series
2017 Android TVs
  • XE80, XE83, XE85, XE90, XE93, XE94 and A1 Series
2018 Android TVs
  • XF75, XF80, XF83, XF85, XF87, XF90, AF8, AF9 and ZF9 Series
