I have two NEW problems (among the other i already have) with my TV. Today i found it OPEN to the bluetooth setup page (!). So now my TV goes from standby to ON with no reason (!!!).
Trying to disable Bluetooth to OFF (and then shut the TV), i see Bluetooth is always ON and can't be turn off.
I must say that i'm not that happy with my Sony TV. A lot of problems remain unfixed, even after all the updates and stuff.
Hi Costas,
It's probably best to contact support about these ongoing issues with your TV. You'll find them here.
Best wishes,
EdwinaU
Kosta have you installed latest Android 6 firmware? I had this issue before Marshmallow.
If you have already installed Marshmallow then you do something wrong during disabling.
Do not press twice "No" during procedure. Second prompt for disabling must a "Yes"
Χρόνια πολλά, καλά Χριστούγεννα
Yes Android 6.
I will try again. Thanks και επισης Χρονια Πολλα.
Tried again, no luck.
