I cannot connect my BT Smarthub2 to my XR-55X9xK Lan connection help required
Billeboy7475
New
5 REPLIES 5
royabrown2
Hero
@Billeboy7475
Is this via WiFi or Ethernet cable?
What steps are you taking to make the connection, at what stage does it fail, and what error message, if any, is being given?
My favourite bedtime reading is a Sony product manual…
Billeboy7475
New
Hi it connected to wifi but I keep getting a message that it has lost the wifi connection but the WIFI  has not dropped out (iphone and Ipad all still connected).hence trying to see if the Lan would connect I did read somewhere that if the router uses POP then it will not work with my TV
Piscie
Hey @Billeboy7475, is this the first time you have connected the TV to the BT Smarthub2?
Is there any way to connect the TV to a different network source, even a WiFi hotspot, to see if the issue remains or not? This would help you confirm if it's a TV related issue or not.
Billeboy7475
New
Thanks for information but I have decided to live with it
Billeboy7475
New
Thank you for info but I am going to live with it
