Gamepad for Sony Bravia KD-49XG8096
Since Dual Shock 4 is no longer compatible with the Sony Bravia TV, is there any other gamepad that I can use with my KD-49XG8096 TV (wired OR wireless)? Thanks.
2 REPLIES 2
Sean_Mc
Moderator
Hi Bruno,
Welcome to the Sony Community.
I'd recommend posting your question over on the Sony PlayStation forum for further advice here.
Best wishes,
Sean
Hi
I have the 2019 version of this Tv and both the PS4 gamepad and Xbox One gamepad work with it. The only problem I found with the xbox one controller is that that it constantly needed to be re-paired once it disconnected from the TV. I have just ordered a cheap gamepad from Amazon that is supposed to work with Android TV, will post if it works Ok when it arrives in a couple of days.
